Browse Forums Building A New House 1 Jul 17, 2021 1:54 pm also posted in ownerbuild but no replies after one week hopefully a plumber will see it here just curious in victoria is it legal for owner builder to install underfloor hydronic pex tubing in timber subfloor and then have plumber make final connection to boiler as there is a lot of labour involved in just laying out the tubing hoping owner builder can do this part Re: hydronic underfloor heating 3Jul 20, 2021 6:59 pm timber particle board subfloor, then hydronic pipes set in plywood, then finished engineered hardwood over the top, and screed with tiles in wet areas more concerned with installing the piping which i estimate will take several days Re: hydronic underfloor heating 4May 26, 2024 7:19 am Hey, did you find someone? I need a reliable company, if you know of one could you give me the contact? Re: hydronic underfloor heating 5May 26, 2024 7:20 am Hey there! I looked into this when I was considering underfloor heating for my place in Victoria. From what I gathered, owner-builders can indeed lay out the hydronic PEX tubing in the timber subfloor. However, the final connection to the boiler must be done by a licensed plumber. It saves a lot of labor costs if you do the tubing yourself, but make sure it's done right to avoid any issues. Last year, I had some electrical problems with my underfloor heating installation, and I needed professional help. The electricians were crucial in ensuring everything was connected safely and correctly. A friend recommended a great company with electricians available 24/7, which was a lifesaver. They sorted out the issues quickly. You can find out more information here about underfloor heating installation . Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 5477 1 10467 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 5382 |
