Browse Forums Building A New House Re: Brick quantities for new home 2Jul 06, 2021 11:11 am Hey mmn Welcome to the forum Generally above and below windows, door sills where they can be seen should all be solids also check with the brickie width mm /240mm = no of bricks. If your house was designed using 3D Bim the Quantities can be extracted 3D BIM Brick quantities always wise to double check also read/follow the engineering notes under masonry Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Brick quantities for new home 3Jul 06, 2021 3:33 pm StructuralBIMGuy Hey mmn Welcome to the forum Generally above and below windows, door sills where they can be seen should all be solids also check with the brickie width mm /240mm = no of bricks. If your house was designed using 3D Bim the Quantities can be extracted 3D BIM Brick quantities always wise to double check also read/follow the engineering notes under masonry Hey StructuralBIMGuy Thanks a lot! Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 5476 Is it just a report written to give to the bank initially and it is based on what and how your payments are made up for, or is it a full service where they go out and… 2 2986 Skjm You might want to watch this video: https://www.youtube.com/watch?v=CKx-bsOr2jg If that link doesn't work go to youtube and search for Zac Homes ACA I am really… 1 3058 |
