Browse Forums Windows & Doors Re: Gaps in Aluminium Window/Door frames 3Jun 22, 2021 5:14 pm Thank you. Do you have any suggestions for what we fill the aluminium in with? I think it’s hollow so we’re not sure if whatever we use will just fall into the frame. Would you say both jobs are simple enough to do ourselves? We haven’t been able to find anyone to help us out with it yet. Re: Gaps in Aluminium Window/Door frames 4Jun 22, 2021 5:18 pm Simple yes, but messy if you have never done it before. There are trades that can do this for you - try Facebook marketplace. Use the same silicone to cover the aluminium gaps, or buy some builders' bog in Bunnies "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Gaps in Aluminium Window/Door frames 5Jun 22, 2021 8:12 pm ECOECO Simple yes, but messy if you have never done it before. There are trades that can do this for you - try Facebook marketplace. Use the same silicone to cover the aluminium gaps, or buy some builders' bog in Bunnies Thanks for your help! Re: Gaps in Aluminium Window/Door frames 7Jul 24, 2021 9:52 pm Hi, I would recommend to have the rubber seals removed and caulked with a UV stable silicone, as the rubbers shrinking and pulling away at the corners will be caused by exposure to the sun. We do plenty of this and were just actually doing one today, feel free to head over to our website at https://www.correctcaulking.com.au/Caulking-Melbourne/ and send us an email if you would like some more advice. Thanks, Jono-Correct Caulking Re: Gaps in Aluminium Window/Door frames 8Jul 28, 2021 11:57 am CorrectCaulking Hi, I would recommend to have the rubber seals removed and caulked with a UV stable silicone, as the rubbers shrinking and pulling away at the corners will be caused by exposure to the sun. We do plenty of this and were just actually doing one today, feel free to head over to our website at https://www.correctcaulking.com.au/Caulking-Melbourne/ and send us an email if you would like some more advice. Thanks, Jono-Correct Caulking The biggest reason for the seals pulling away from the corners is the fabricator stretching the seal during assembly. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 To validate the certificate, I need to confirm if it aligns with the requirements outlined in AS1288 - 2021 Section 5, clause 5.23.1 & 5.23.3, AS2047-2014 clause 8.1 &… 5 1578 Sorry I missed this, simply put this is a pathetic job, and as it stands it is non-compliant... I think the worst part is not in the quality of the workmanship so much… 5 5191 |
