Browse Forums Building A New House Re: Sliding door, stacker door size 3Jun 06, 2021 5:00 pm Spazzen I'm putting a 6m stacker in my new build. Cost 5.5k less the sliding door and windows I was credited. No extra support is better added, only single story though so a two story building might be different. Got quotes for a 9m stacker at 16k and decided against spending 10k more for 3 extra metres. I'd also check the panel sizes some 6 metre doors were 4 panel which looks nicer but you only get a 3m opening, I went with a 6 panel door, 2 extra frames but I get a 4m opening. 5.5k is very reasonable. I think I will go ahead and put a 5m door in. I think it will be something I will regret not doing later on. Thanks for the reply Re: Sliding door, stacker door size 4Jul 09, 2021 3:19 pm Spazzen I'm putting a 6m stacker in my new build. Cost 5.5k less the sliding door and windows I was credited. No extra support is better added, only single story though so a two story building might be different. Got quotes for a 9m stacker at 16k and decided against spending 10k more for 3 extra metres. I'd also check the panel sizes some 6 metre doors were 4 panel which looks nicer but you only get a 3m opening, I went with a 6 panel door, 2 extra frames but I get a 4m opening. Our opening is 7m. 2 panels that slide back to a 3rd panel at either end (ie. 6 panels in total). Have paid an extra 5k on top of the standard doors. Already had beams in place due to supporting the 2nd level so no extra cost there. 100% worth it from a lifestyle and resale perspective. Re: Sliding door, stacker door size 5Aug 06, 2021 9:58 am A 6m wide is a standard biparting stacker - 4 active panels and 2 fixed. The extrusions are manufactured as 6m standard, The height is also important. We could make 7.2m wide... just have not done it yet. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as… 6 7914 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12400 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16186 |
