Browse Forums Building A New House Re: Starting Over - Custom Build 2Apr 17, 2021 6:40 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Starting Over - Custom Build 4Jun 01, 2021 3:04 pm Awesome views from the block! Do you have any concept sketches you can share yet? cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Starting Over - Custom Build 5Jun 02, 2021 8:17 am No working drawings yet. We've got some ideas on key design features and basic layout but nothing is set yet. We are trying to avoid the tri-level type house. The slope is not overly steep so we are aiming for split level somewhere in the house. Re: Starting Over - Custom Build 6Jun 04, 2021 4:16 pm Some movement! Just got word the Site Survey has been completed and will be ready early next week. Have also booked the initial Design Consult for next Wednesday 9/6/2021. Re: Starting Over - Custom Build 7Jul 02, 2021 3:10 pm Re: Starting Over - Custom Build - First Pass at the design 8Jul 08, 2021 1:58 pm Here is the First Pass at the design. We had a follow up meeting with the Builder's Architect 7/7/21, and made some changes to both levels. We also added a bit more cash into the budget to get what we want. Items we are changing Ground Floor - Built in Desk is being removed and Butler's Pantry made larger. - Garage is being increased in depth by 2 m - BIR's being added to the ground floor Bedroom and its being slightly enlarged - 4m high ceiling added to Living, and Dining areas First Floor - Master bedroom is being reconfigured for his and hers WIR's - Bedroom at the front is being enlarged and the BIR is being halved and a built in desk incorporated. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Starting Over - Custom Build - Plans 2.0 9Jul 28, 2021 11:37 am Received revised plans yesterday 27/7/2021 We are getting close to the final plans and I'm much happier with these revised layouts. A few things to tweak a little further - 1. Study to be made larger to better use the wasted space in the entry 2. Media / Theater to be reconfigured - Rotated by 90 Deg. TV to be placed on the external wall. Dual Swing doors to be replaced with Solid Core Cavity Doors. 3. Master WIR to be made larger (Wall indent to be flipped out) making the WIR square. WIR will then be large enough to split into a His and Hers. Delete WIR Door and replace with square set opening Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Starting Over - Custom Build - Plans 2.0 10Aug 11, 2021 8:44 pm Nice! Is that a split level on both the ground floor and the 1st floor? I like it. I've been trying to get my favorite volume builder to do that but they can only do split on the ground floor Re: Starting Over - Custom Build - Plans 2.0 11Aug 12, 2021 6:50 pm [quote="boris594"]Nice! Is that a split level on both the ground floor and the 1st floor? I like it. I've been trying to get my favorite volume builder to do that but they can only do split on the ground floor /quote] Yes, essentially there is a split on both levels. Entry down to kitchen / dining / living has a split and then there is a split from Master / Bed 3 level up to Bed 2 and Activity. A 2.5m fall across the build envelope is challenging, but not impossible to work and live with. Re: Starting Over - Custom Build - Plans 3.0 12Oct 15, 2021 3:12 pm Bit of an update. We ended up engaging with another custom builder and I pretty much reworked 95% of my design. The house now has 2 smaller splits downstairs and a traditional staircase to the upper level. Family situation has also changed so needed to accommodate an oversized Guest Bed / 2nd Master on the entry level. Managed to get 2590mm height ceilings upstairs and we are really happy about the 4.3 for the lower Kitchen / Dining / Living areas. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Custom Build - New Plans added - check them out! 14Oct 15, 2021 5:34 pm It's brick veneer where the bricks sit on lower level brick and weather board clad frame elsewhere. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Custom Build - New Plans added - check them out! 15Oct 15, 2021 6:00 pm chippy It's brick veneer where the bricks sit on lower level brick and weather board clad frame elsewhere. Correct, the cladding is represented by the thinner wall line on the upper level. Re: Custom Build - New Plans added - check them out! 17Oct 18, 2021 12:57 pm Blonde Looks great, what a good block size. Cheers thanks. We had been planning this for a while and looking for the right property at the same time. This opportunity presented itself so we jumped on it. Re: Custom Build - New Plans added - check them out! 18Jan 20, 2022 3:27 pm After a number of changes back and forth with the builder and now after a break over Christmas / New Year, the Tender Presentation is locked in for Monday 24/1/2022. With the sloping site and the presence of rock, we are little anxious to learn the sites costs component as this may affect other parts of the build in terms of fit and finish. We did receive a heads up from the builder that we are less than $10K over our budgeted number. Will know for sure on Monday. Re: Custom Build - Tender Presentation 24th Jan 19Jan 21, 2022 11:32 am Hi there KnockItDown Your whole journey was fascinating to read. What an adventure! How did you go about preparing the tender for builders? Did an estimator do a BOQ estimate for you? I have been blogging about custom home building. The information might prove useful to you at the moment. Here is a link to an ultimate guide to custom home building Here are 9 best contract negotiation tactics In the coming weeks, I will write more about the whole process, but if you have any questions, I am happy to help! Regards, Colin Operations Director Homebuildguide.com.au Click Here For A Free eBook About Custom Home Building Re: Custom Build - Tender Presentation 24th Jan 20Jan 21, 2022 4:16 pm Hi Colin, I did the original designs of the house which I drew myself based on what we wanted. I then approached a number of builders to see if they could build to my design. As expected, a number of builders weren't interested due to the slope (2.5 metre fall over the build envelope). I started along the initial sketch / site layout process with 2 builders and then settled on the one that could meet our needs and could also build what we wanted to the budget we had. That builder is presenting their formal tender to us on Monday. All things going well we will progress from there. Tradie may sit at home but will need to get house plastered as well or will you sit it out? 6 10060 I engaged my builder in December last year and we’ve been working on preliminary drawings for last couple of months. I got a call from the salesperson this morning… 0 629 The tank is around 200 litres (I am on holiday for the next 6 weeks so can't check) The Heat Pump has a built in time switch. No idea on the speed to heat because with… 6 2452 |
