About to start work on a standalone garage. 6mx6m
Which wall should I fit an EV charger?
Browse Forums Building A New House Re: EV charging point location in garage 2May 25, 2021 9:14 am Thylacene About to start work on a standalone garage. 6mx6m Which wall should I fit an EV charger? on the wall opposite the door Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: EV charging point location in garage 5May 27, 2021 6:16 pm Hi all.. Not trying to be confrontational… Surely it depends on if you reverse in or drive in? J Re: EV charging point location in garage 6May 27, 2021 7:45 pm EvryThingIsNormal Hi all.. Not trying to be confrontational… Surely it depends on if you reverse in or drive in? J Haha I was thinking the same thing. But seriously, I'd be getting a cable run to both sides anyway, at least if you have a double garage. Won't cost all that much more and I'd be expecting EVs to be a big thing in the next 10 years anyway. Re: EV charging point location in garage 8Jul 02, 2021 8:14 pm For my new home build I'm covering all bases... A 3 Phase 32A Circuit on the back wall of the garage and 1 Phase 32A Circuits on either side towards the front of the garage. On either side of the house I also have 15A GPO's. Probably excessive but I do like my toys. It is true that a builder can ignore your independent inspection report as it is not part of the contractual arrangement but that is stupid because he cannot avoid fixing… 9 46887 |
