Browse Forums DIY, Home Maintenance & Repair Re: Trying to remove fence panels 2Apr 21, 2021 11:59 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Trying to remove fence panels 3Apr 22, 2021 9:04 pm chippy They look like Ramset suredrive fixings that have been powder coated black. If you don't need to save the existing fencing then the simplest way is to take a grinder and remove the heads. You can then drive the rest of the fixing down into the hole and patch it. You can try levering the whole plug out but you run the risk of breaking away the wall. Thanks so much. You were bang on with the fixings. Ended up using grinder To do the job. Thanks very much for your advice. It’s greatly appreciated I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7551 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 |
