Browse Forums Building A New House Re: Retaining wall & 7Apr 13, 2021 2:23 pm KnockItDown You need to check with your local council as they all have different rules when it comes to retaining walls. Some Councils allow up to 1m high without DA, whereas some set the height at up to 750mm high without DA. If you need to submit a DA for your retaining wall then you will need to have the specs of the wall (material / foundation / drainage / etc.) provided by a suitably qualified person in the landscaping industry. Yes, I have got the architect and engineering drawings. Re: Retaining wall & 8Apr 13, 2021 8:56 pm Revinator They wont accept it unless a planner has written it, and you will be knocked back at Council FYI. You could also search their DAs on display to read other people’s SOEE, some are very basic and brief good luck Re: Retaining wall & 9Apr 14, 2021 8:45 am Pulse Revinator They wont accept it unless a planner has written it, and you will be knocked back at Council FYI. This is not a requirement, especially for such a basic development. SOEE can easily be written by a layperson, most councils have templates. You could also search their DAs on display to read other people’s SOEE, some are very basic and brief good luck Thanks for this. will search some template. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16157 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
