Browse Forums Building A New House Re: Advice on Floor plan 3Mar 30, 2021 7:05 pm fatboy1 Hi Guys We are building a double storey in Melbourne, This is an east facing block ( rear of block is west). The house on North side is higher to our block, while the one on east side is slightly lower than our block. The width of block is 19.5 and length is about 43.5 meters. There is an easement at rear of the block about 2 or 3 meters. We are looking to build with Metricon from Signature series - Lumiere façade. We want to have a pool on the north side of the plot between the boundary of the other house. The rear of the house will be lawn . I have attached the original floor plan and the changes we have made below. We appreciate all comments and critiques . We have shifted the garage door on the west side so that a roller door can be installed at the rear of the garage , plans for 2 tandem car park by side of the house when we have more cars or go away on holidays. Thank you guys Happy sharing knowledge Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ making the garage wider with enough space to drive and park on the south side without losing too much space off the north side garden for the pool my suggestions include some ideas to consider Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice on Floor plan 4Mar 30, 2021 10:30 pm oklouise fatboy1 Hi Guys We are building a double storey in Melbourne, This is an east facing block ( rear of block is west). The house on North side is higher to our block, while the one on east side is slightly lower than our block. The width of block is 19.5 and length is about 43.5 meters. There is an easement at rear of the block about 2 or 3 meters. We are looking to build with Metricon from Signature series - Lumiere façade. We want to have a pool on the north side of the plot between the boundary of the other house. The rear of the house will be lawn . I have attached the original floor plan and the changes we have made below. We appreciate all comments and critiques . We have shifted the garage door on the west side so that a roller door can be installed at the rear of the garage , plans for 2 tandem car park by side of the house when we have more cars or go away on holidays. Thank you guys Happy sharing knowledge Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ do you want the downstairs ensuite between two bedrooms or the front room to be the sitting room and the old sitting room to be a bedroom with ensuite, what about bathroom access from the pool and alfresco? ..could the ensuiite and/or the laundry and powder room be located on the north side? and upstairs rooms be separated from teh voids for better control of noise and zoning for AC? Hi Oklouise Thank you for your response. The front room on rt on entry will be a sitting room which we plan to also use a theatre room. The area under the void will not be living, after speaking to a draftsman, it was suggested to keep the dining room under the void. If we make this area into a living room, there can be echo from the TV sound. Pool will be on the alfresco and dining side. We need to have a door on this side. The option I am thinking is to put a sliding door at one end of dining room to out side - other side of pool. In first floor, we have master bedroom at rear - at west end of the house - not a good option in summer. As this is in Melbourne area, do not know how harsh will Summer will be. All bedrooms will have an ensuite. Planning to have a small gym room. Not sure how to make changes to put one Re: Advice on Floor plan 5Mar 30, 2021 10:52 pm oklouise fatboy1 Hi Guys We are building a double storey in Melbourne, This is an east facing block ( rear of block is west). The house on North side is higher to our block, while the one on east side is slightly lower than our block. The width of block is 19.5 and length is about 43.5 meters. There is an easement at rear of the block about 2 or 3 meters. We are looking to build with Metricon from Signature series - Lumiere façade. We want to have a pool on the north side of the plot between the boundary of the other house. The rear of the house will be lawn . I have attached the original floor plan and the changes we have made below. We appreciate all comments and critiques . We have shifted the garage door on the west side so that a roller door can be installed at the rear of the garage , plans for 2 tandem car park by side of the house when we have more cars or go away on holidays. Thank you guys Happy sharing knowledge Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ making the garage wider with enough space to drive and park on the south side without losing too much space off the north side garden for the pool my suggestions include some ideas to consider Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Oklouise fantastic design. I like the entry to master bedroom and also the good use of space under the stairs. I feel this can better help with zoning for AC. How can we make the living area in first floor a little bigger . Thanks for your suggestions. Re: Advice on Floor plan 6Mar 31, 2021 3:16 pm fatboy1 oklouise fatboy1 Hi Guys We are building a double storey in Melbourne, This is an east facing block ( rear of block is west). The house on North side is higher to our block, while the one on east side is slightly lower than our block. The width of block is 19.5 and length is about 43.5 meters. There is an easement at rear of the block about 2 or 3 meters. We are looking to build with Metricon from Signature series - Lumiere façade. We want to have a pool on the north side of the plot between the boundary of the other house. The rear of the house will be lawn . I have attached the original floor plan and the changes we have made below. We appreciate all comments and critiques . We have shifted the garage door on the west side so that a roller door can be installed at the rear of the garage , plans for 2 tandem car park by side of the house when we have more cars or go away on holidays. Thank you guys Happy sharing knowledge Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ making the garage wider with enough space to drive and park on the south side without losing too much space off the north side garden for the pool my suggestions include some ideas to consider Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Oklouise fantastic design. I like the entry to master bedroom and also the good use of space under the stairs. I feel this can better help with zoning for AC. How can we make the living area in first floor a little bigger . Thanks for your suggestions. best way to have more useful living area upstairs is to reduce or avoid the voids or reduce the size of bed 4 suite but how will you use the upstairs living room so i can make alternate suggestions Re: Advice on Floor plan 7Mar 31, 2021 3:23 pm fatboy1 oklouise fatboy1 Hi Guys We are building a double storey in Melbourne, This is an east facing block ( rear of block is west). The house on North side is higher to our block, while the one on east side is slightly lower than our block. The width of block is 19.5 and length is about 43.5 meters. There is an easement at rear of the block about 2 or 3 meters. We are looking to build with Metricon from Signature series - Lumiere façade. We want to have a pool on the north side of the plot between the boundary of the other house. The rear of the house will be lawn . I have attached the original floor plan and the changes we have made below. We appreciate all comments and critiques . We have shifted the garage door on the west side so that a roller door can be installed at the rear of the garage , plans for 2 tandem car park by side of the house when we have more cars or go away on holidays. Thank you guys Happy sharing knowledge Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ do you want the downstairs ensuite between two bedrooms or the front room to be the sitting room and the old sitting room to be a bedroom with ensuite, what about bathroom access from the pool and alfresco? ..could the ensuiite and/or the laundry and powder room be located on the north side? and upstairs rooms be separated from teh voids for better control of noise and zoning for AC? Hi Oklouise Thank you for your response. The front room on rt on entry will be a sitting room which we plan to also use a theatre room. The area under the void will not be living, after speaking to a draftsman, it was suggested to keep the dining room under the void. If we make this area into a living room, there can be echo from the TV sound. Pool will be on the alfresco and dining side. We need to have a door on this side. The option I am thinking is to put a sliding door at one end of dining room to out side - other side of pool. In first floor, we have master bedroom at rear - at west end of the house - not a good option in summer. As this is in Melbourne area, do not know how harsh will Summer will be. All bedrooms will have an ensuite. Planning to have a small gym room. Not sure how to make changes to put one do you plan for a separate pool house or would you like access to a toilet and changing room from outside and do you want the gym upstairs or downstairs and what size space do you need and do you mean a spearte ens for each bedroom instead of the shared bathroom for beds 2 and 3?? Re: Advice on Floor plan 8Apr 02, 2021 10:39 pm another variation with the bigger void used to make space for a dual access gym big enough for full sized equipment, a north facing master bedroom and retreat, more spacious ens and wiw with dressing table nook but i've kept the shared bathroom between beds 2 and 3 as it is more spacious than two small ens and includes a full bath and separate powder room and enough space for bigger bedrooms Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice on Floor plan 9Apr 08, 2021 12:03 am oklouise another variation with the bigger void used to make space for a dual access gym big enough for full sized equipment, a north facing master bedroom and retreat, more spacious ens and wiw with dressing table nook but i've kept the shared bathroom between beds 2 and 3 as it is more spacious than two small ens and includes a full bath and separate powder room and enough space for bigger bedrooms Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Fantastic suggestions But I need to keep the void to keep my wife. She is very particular about the void. Please look at my new version of the plan and critique. Thank you Re: Advice on Floor plan 10Apr 08, 2021 12:13 am Ground floor Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ first floorLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have added space between bedroom and stairs in ground floor for gym and sauna. The shaded area at the rear is the easement which has sewage pipes. If we can build with zero boundary this will solve some of the issues for the pool. In first floor swaped Bed 2 and leisure which will be also a theatre room. All bedrooms with ensuite. Please critique and comment. Thank you Re: Advice on Floor plan 11Apr 08, 2021 11:46 am fatboy1 Ground floor Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ first floorLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have added space between bedroom and stairs in ground floor for gym and sauna. The shaded area at the rear is the easement which has sewage pipes. If we can build with zero boundary this will solve some of the issues for the pool. In first floor swaped Bed 2 and leisure which will be also a theatre room. All bedrooms with ensuite. Please critique and comment. Thank you i'm not a fan of voids because they share too much noise and kitchen smell all around the house but you know what they say about a happy wife but will attempt to copy your new plan to clarify room sizes and reconsider my opinon Re: Advice on Floor plan 12Apr 10, 2021 2:27 pm fatboy1 Ground floor Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ first floorLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have added space between bedroom and stairs in ground floor for gym and sauna. The shaded area at the rear is the easement which has sewage pipes. If we can build with zero boundary this will solve some of the issues for the pool. In first floor swaped Bed 2 and leisure which will be also a theatre room. All bedrooms with ensuite. Please critique and comment. Thank you your revised plans are much bigger than i first estimated but there was no allowance for wall thicknesses so some spaces needed to be reduced to allow for the extras (including the pool with walkway and through access from the garage and, based on standard sizes for sauna and gym equipment i've sacrificed the guest wiw for the sauna and shower room in a bigger gym with direct access to the pool for a swim after exercise and also for access from outside without having to walk through the living areas to get to the powder room from outside.... upstairs there's enough room for twin wiw's in the master suite, a utility room for cleaning equipment, sink and optional extra wash machine and the laundry shute ...and bedrooms and upstairs living area can be closed off from the voids to better control AC and noise but all the windows need to be reviwed to ensure best size and placement to oversee outdoor activities and i've suggested a French Balcony with screens for the western window in the master bedroom Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice on Floor plan 13Apr 11, 2021 3:46 pm a revised version of my last suggestion with size reductions that saves about 47 sqm off downstairs that should allow enough extra space for a super generous alfresco across the western side of the house and extra space for the pool and distance from northern neighbour ... is 41 sqm smaller without loss of generous bedrooms and the roof would be simpler Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ labels have been omitted to make it easier to see how furniture fits within new sized rooms and there's still still two geerous voids and ensuites for every bedroom i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17421 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25265 Hi there! Absolutely agree on the wasted space. We have no desire for the master to be that oversized, but it occurred when we increased the depth of the garage. We have… 4 12589 |
