Browse Forums General Discussion Re: Defect advice 2Mar 19, 2021 6:35 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Defect advice 5Mar 19, 2021 8:33 pm Thanks, guys ill take a look, I've had a building inspector out but seems like they just pick on easy stuff and won't say much regarding my skirting boards. It all started with my slab, just wish i never paid. Most of my frame work has packers under it and all my door frames/window frames are cracking and even after been repaired crack within a few weeks again. Re: Defect advice 6Mar 19, 2021 8:33 pm Thanks, guys ill take a look, I've had a building inspector out but seems like they just pick on easy stuff and won't say much regarding my skirting boards. It all started with my slab, just wish i never paid. Most of my frame work has packers under it and all my door frames/window frames are cracking and even after been repaired crack within a few weeks again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Defect advice 7Mar 19, 2021 8:48 pm Had a quick read of the guide, thanks for that. I can't find anything regarding the walls on horizontal only vertical, with tiles I'm not sure what it will come under too as a defect? I'm also in SA, does this make a difference since the guide is for Vic? Seems really hard to find standards/codes online without paying for stuff. Re: Defect advice 8Mar 20, 2021 12:43 pm adrian20 Thanks, guys ill take a look, I've had a building inspector out but seems like they just pick on easy stuff and won't say much regarding my skirting boards. It all started with my slab, just wish i never paid. Most of my frame work has packers under it and all my door frames/window frames are cracking and even after been repaired crack within a few weeks again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ what is this a picture of? Please dont tell me your Slab? Re: Defect advice 9Mar 20, 2021 3:12 pm adrian20 Had a quick read of the guide, thanks for that. I can't find anything regarding the walls on horizontal only vertical, with tiles I'm not sure what it will come under too as a defect? I'm also in SA, does this make a difference since the guide is for Vic? Seems really hard to find standards/codes online without paying for stuff. The Vic guide follows the Australian Standards which are applicable for SA. See page 48: "9.01 Verticality or plumbness of internal and external wall surfaces Wall surfaces are defective if they deviate from vertical by more than 5 mm over a 1.8 m straight edge. Refer to Diagram E on page 13 of this Guide. 9.02 Straightness of internal and external wall surfaces Walls are defective if they deviate from plane (bow) by more than 5 mm over a 1.8 m straight edge. This tolerance includes internal walls with a build-up of plaster at internal and external corners of the plasterwork." Re: Defect advice 10Mar 20, 2021 4:42 pm Fore2 adrian20 Thanks, guys ill take a look, I've had a building inspector out but seems like they just pick on easy stuff and won't say much regarding my skirting boards. It all started with my slab, just wish i never paid. Most of my frame work has packers under it and all my door frames/window frames are cracking and even after been repaired crack within a few weeks again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ what is this a picture of? Please dont tell me your Slab? Yep Re: Defect advice 11Mar 20, 2021 4:48 pm Kippers01 adrian20 Had a quick read of the guide, thanks for that. I can't find anything regarding the walls on horizontal only vertical, with tiles I'm not sure what it will come under too as a defect? I'm also in SA, does this make a difference since the guide is for Vic? Seems really hard to find standards/codes online without paying for stuff. The Vic guide follows the Australian Standards which are applicable for SA. See page 48: "9.01 Verticality or plumbness of internal and external wall surfaces Wall surfaces are defective if they deviate from vertical by more than 5 mm over a 1.8 m straight edge. Refer to Diagram E on page 13 of this Guide. 9.02 Straightness of internal and external wall surfaces Walls are defective if they deviate from plane (bow) by more than 5 mm over a 1.8 m straight edge. This tolerance includes internal walls with a build-up of plaster at internal and external corners of the plasterwork." Thank you very much Re: Defect advice 12Mar 20, 2021 5:05 pm adrian20 Fore2 adrian20 Thanks, guys ill take a look, I've had a building inspector out but seems like they just pick on easy stuff and won't say much regarding my skirting boards. It all started with my slab, just wish i never paid. Most of my frame work has packers under it and all my door frames/window frames are cracking and even after been repaired crack within a few weeks again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ what is this a picture of? Please dont tell me your Slab? Yep /quote] who did you build with and who done ya slab? That is bad as (sorry) Re: Defect advice 14Mar 22, 2021 2:06 pm faaaark. that slab... I feel bad for you mate. Looks like they just pumped it in and left it to cure without any screeding. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Defect advice 15Mar 22, 2021 5:22 pm Added some more photos to the folder with a level on the skirting boards, also noticed the rear sliding door frame is very badly warped. It out by around 10mm I've tested my water pressure its 350KPA at the garden tap which is the first thing after the mains. Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11308 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5399 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10205 |
