Hi, I am after Durisol Builder in Sydney for a duplex.
I original wanted a medium size project builder to do it all. Do any of them use Durisol?
If not, pleas inbox me builders that I could potentially call and find out more.
Thanks,
Sanja
Browse Forums Building A New House Re: Durisol Builder in Sydney 2Mar 10, 2021 11:19 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Durisol Builder in Sydney 4Mar 10, 2021 1:02 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Durisol Builder in Sydney 6Mar 10, 2021 1:20 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Durisol Builder in Sydney 7Mar 10, 2021 1:22 pm alexp79 Hi Simeon, My calcs for Rendered Brick Veneer breakdown: 1) $50 per sqm for render (in Sydney I have seen some ppl are asking even more) 2) $2.5 per brick x 52 = $130 3) $50 for framing 4) at least $15 for insulation plus wrapping 5) $30+ for plaster Where am I missing out? LOL, You calcs are way out mate eg, That's $60/m2 try 2c bricks 20 bricks /m2 ( $3 L & M) Trades and builders will always try to justify extras Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Durisol Builder in Sydney 8Mar 10, 2021 1:24 pm StructuralBIMGuy alexp79 Hi Simeon, My calcs for Rendered Brick Veneer breakdown: 1) $50 per sqm for render (in Sydney I have seen some ppl are asking even more) 2) $2.5 per brick x 52 = $130 3) $50 for framing 4) at least $15 for insulation plus wrapping 5) $30+ for plaster Where am I missing out? LOL, You calcs are way out mate eg, That's $60/m2 try 2c bricks 20 bricks /m2 ( $3 L & M) Trades and builders will always try to justify extras 2c bricks are cheaper or labour is cheaper? Why not everyone is using them, then? Re: Durisol Builder in Sydney 9Mar 10, 2021 1:29 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ LOL, Everyone is using them in perth they are Fire rated, Structurally Load bearing, Cheap, quick to put up, etc,etc HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Durisol Builder in Sydney 10Mar 10, 2021 1:35 pm alexp79 StructuralBIMGuy alexp79 Hi Simeon, My calcs for Rendered Brick Veneer breakdown: 1) $50 per sqm for render (in Sydney I have seen some ppl are asking even more) 2) $2.5 per brick x 52 = $130 3) $50 for framing 4) at least $15 for insulation plus wrapping 5) $30+ for plaster Where am I missing out? LOL, You calcs are way out mate eg, That's $60/m2 try 2c bricks 20 bricks /m2 ( $3 L & M) Trades and builders will always try to justify extras 2c bricks are cheaper or labour is cheaper? Why not everyone is using them, then? Alex, My core point is that whatever market you are in, its smart to choose a building material that is common to that market, and that way you will get the best number of trades with experience and enough trades to be able to negotiate a good price. I have heard so many people on here talk about how great Durisol is so I started investigating for a client and I was shocked at how expensive it was compared to what I believe is a relatively low benefit when compared to building materials that are already in the market. In the US where in the colder climates that have very strict thermal requirements for their new builds they are getting R50 and still using timber framing and cladding. Its possible to use timber frames and insulate the home by sealing every single gap. Te other issue with Durisol is the width of the blocks, They are 300-365mm thick so you end up losing usable floor area. They are also very heavy and therefore material handling becomes a bigger issue. Anyway, you might disagree and that is fine. After all this is just a place we can all express our opinions in a friendly manner If you dont like corefilled concrete blocks In Sydney another alternative is Dincel as this is used quite a lot, especially in apartment construction, so again there are a lot of trades with experience. Cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au 10 15813 |
