Browse Forums Windows & Doors Re: Remove a door 5Mar 04, 2021 1:46 pm The rollers are adjustable to help with leveling the door and aligning the lock with the keeper, there's a screw in the end of the panel and level with the roller. Gently take the weight off the roller by levering it up and with a screwdriver lower the panel. Do that for both sides. Hopefully it's enough to release the panel. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Remove a door 6Mar 04, 2021 1:59 pm Thank you i wilo try. I called nu-eco the manufacturer and they said it cant be done Re: Remove a door 7Mar 09, 2021 4:06 pm Johnnyboy123 Thank you i wilo try. I called nu-eco the manufacturer and they said it cant be done I doubt that, unless the fixed panel is attached to the jamb from outside the jamb. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5900 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11829 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7063 |
