Browse Forums General Discussion 1 Feb 23, 2021 5:01 pm Re: Identify pipe 2Feb 27, 2021 1:04 pm Just further to this, it appears to go most of the entire length of the boundary and looks to go 90degrees downwards around 1.5m from the water meter. I am assuming it is some sort of old irrigation or other piping from prior to the house being built (before 1978ish). I understand it was farm land prior to being developed Re: Identify pipe 3Feb 28, 2021 7:38 pm It is most likely an old gal water service pipe We are Expert Consultant's, and we are here to help. OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19816 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7247 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4766 |
