Browse Forums General Discussion Re: Minor Changes to Driveway size before Occupation Certifi 2Feb 17, 2021 9:02 am You are placing the crossover on council property and they will check for compliance upon completion If it's non compliant you will be forced to rip it up...resubmit plans goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Minor Changes to Driveway size before Occupation Certifi 3Feb 17, 2021 9:12 am StructuralBIMGuy You are placing the crossover on council property and they will check for compliance upon completion If it's non compliant you will be forced to rip it up...resubmit plans goodluck Thanks structuralBIMGuy Appreciate the input. Incidently my concreter just called up a min ago and mentioned the same thing. Mentioned he will draw up the formwork (double garage allows upto 5 to 5.5 mts perhaps) and this should be within the range. Before pouring of concerete, the inspector would either decline but most likely should not be a problem. Builders always submit plans to comply to the minimum requirement i've heard. Fingers crossed, however will ring up council etc prior to any work. Joe, it depends on your certifier but we are noticing the ones we deal with are really cracking down. So i would recommend you follow your approved landscaping plans to… 4 10974 Hi Simeon, Thank you for laying it down for us. Makes sense. Appreciate it very much. Have a nice day. Cheers 2 9014 I engaged my builder in December last year and we’ve been working on preliminary drawings for last couple of months. I got a call from the salesperson this morning… 0 558 |
