Browse Forums Building A New House Re: Slab questions 4Feb 14, 2021 9:53 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Slab questions 6Feb 15, 2021 1:34 pm I have 25 years experience as a Concrete Contractor in NSW. I have found Pod Slabs require less skill to construct. Most volume builders use concreters that specialise in Pod Slabs and their workers tend to be less skilled. They will do a better job of a Pod Slab than a Raft Slab. Re: Slab questions 8Feb 24, 2021 1:37 am MisterLevy I have 25 years experience as a Concrete Contractor in NSW. I have found Pod Slabs require less skill to construct. Most volume builders use concreters that specialise in Pod Slabs and their workers tend to be less skilled. They will do a better job of a Pod Slab than a Raft Slab. I live in WA and got some photos of my slab. I’m currently living away and cannot go on site to see works carried out. Relying on them to do their job correctly. A friend took some photos for me of the slab and I thought this might not be an acceptable standard of slab pour. Would you agree and will this cause issues later on? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Slab questions 9Feb 24, 2021 2:25 am MisterLevy I have 25 years experience as a Concrete Contractor in NSW. I have found Pod Slabs require less skill to construct. Most volume builders use concreters that specialise in Pod Slabs and their workers tend to be less skilled. They will do a better job of a Pod Slab than a Raft Slab. 100% recent agree! Re: Slab questions 10Mar 01, 2021 10:19 pm Tbaby MisterLevy I have 25 years experience as a Concrete Contractor in NSW. I have found Pod Slabs require less skill to construct. Most volume builders use concreters that specialise in Pod Slabs and their workers tend to be less skilled. They will do a better job of a Pod Slab than a Raft Slab. I live in WA and got some photos of my slab. I’m currently living away and cannot go on site to see works carried out. Relying on them to do their job correctly. A friend took some photos for me of the slab and I thought this might not be an acceptable standard of slab pour. Would you agree and will this cause issues later on? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10490 We had this happen to us last year and got charged a variation. Try and give away as much as you can that is usable to charity otherwise if you are in Sydney I have a… 1 4511 Not sure what council area you are in. Some LGA's allow zero lot retaining walls. This usually occurs in greenfield developments but not often in established areas. You… 1 8266 |
