Browse Forums Building A New House Re: McDonald Jones Build Tender 16Feb 13, 2021 5:26 pm you will be close to $500k once you come out of the studio and electrical appointments for that size house with a 3rd garage and some nice touches... You will sign your contract first and then any of the selections done through the studio are variations, you should be able to pay this out of pocket if needed. Keep an allowance for basix requirements and rock removal, you may not use it but its there if you need it I said after the 1st build “ never again “ & now im on my 3rd Re: McDonald Jones Build Tender 17Apr 04, 2021 9:09 pm Christopher_Hemmy Also just did a bit of research on houspect as a building inspector. They sound really good and are roughly $2250 for a 4 stage inspection or $2600 for a 5 stage. (5th stage being waterproofing check of wet areas) would the 5th stage be worth it or should I just get 4 stages? It seems like a no brainer getting them to inspect it as 2.5k when spending 400k is nothing...especially after the horror stories I've read! Do housepec cover the mid-north coast? If not any recommendation? Hi AKG, We had a base tender of $592 for 31 squares from MC Donald Jones. It looks relatively cheaper than other builders. But I assume there are many hidden things that… 1 16967 Hey. Head to a metal and decide on which profile you will use first. Profiles with larger corrugations can greatly change the appearance of the color in different… 0 3442 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 18358 |
