Browse Forums Building A New House Re: Sewer inspection line poor placement eyesore 4Jan 23, 2021 2:21 pm That one is an IO so it can be cut down as moudzj stated. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Sewer inspection line poor placement eyesore 5Jan 23, 2021 4:30 pm I replaced one last week. Was in the middle of alfresco and was about to be concreted. I went to Tradelink and they have a small version with a stainless ring around it. Just lift that off as it won't be glued and cut pipe to suit the depth and replace. It was about $25. Re: Sewer inspection line poor placement eyesore 6Jan 23, 2021 6:52 pm Brett0004 I replaced one last week. Was in the middle of alfresco and was about to be concreted. I went to Tradelink and they have a small version with a stainless ring around it. Just lift that off as it won't be glued and cut pipe to suit the depth and replace. It was about $25. This sounds good can you give me the name or model number of it please? Re: Sewer inspection line poor placement eyesore 7Jan 23, 2021 7:55 pm Deacon91 Brett0004 I replaced one last week. Was in the middle of alfresco and was about to be concreted. I went to Tradelink and they have a small version with a stainless ring around it. Just lift that off as it won't be glued and cut pipe to suit the depth and replace. It was about $25. This sounds good can you give me the name or model number of it please? Sorry I am at work and wont be home until next week. I have been searching for it online but no luck. What I did was take a photo of the DWV mound that you have and go into Reece or tradelink and tell them you are after something better than that. Thats what I did although mine was for finished concrete slab and yours is for garden by the looks. There area few different options by the looks. Re: Sewer inspection line poor placement eyesore 8Jan 24, 2021 7:55 am Brett0004 Deacon91 Brett0004 I replaced one last week. Was in the middle of alfresco and was about to be concreted. I went to Tradelink and they have a small version with a stainless ring around it. Just lift that off as it won't be glued and cut pipe to suit the depth and replace. It was about $25. This sounds good can you give me the name or model number of it please? Sorry I am at work and wont be home until next week. I have been searching for it online but no luck. What I did was take a photo of the DWV mound that you have and go into Reece or tradelink and tell them you are after something better than that. Thats what I did although mine was for finished concrete slab and yours is for garden by the looks. There area few different options by the looks. Great thanks for the info will go have a look Re: Sewer inspection line poor placement eyesore 9Jan 29, 2021 3:34 am What you're looking at is the sewer jump-up. This is where your sewer line connects into the sewer main. The connection point is not offered as a "preferred connection location". It is now installed by the builder or as requested by the builder, it happened back when the civils for the estate were being carried out. There is no requirement for it to be installed as a feature point in the front yard at the height above ground as shown. The seal "black lid is a rubber sealed water proof connection, you can have it lowered so it sits flush with the finished grass level We are Expert Consultant's, and we are here to help. Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5396 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6511 |
