Browse Forums Building Standards; Getting It Right! Re: Plasterboard cracks - Builder responsibility 7Jan 21, 2021 9:44 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Plasterboard cracks - Builder responsibility 8Jan 21, 2021 10:35 am StructuralBIMGuy hey Bansi Which state are you in? lodge a complaint with your State Building commission. Structural Serviceability defects should not be accepted in new builds. Cheers Chris These are most likely not serviceability defects. One could only know for sure after a detailed inspection. Re: Plasterboard cracks - Builder responsibility 9Jan 21, 2021 11:39 am moudzj StructuralBIMGuy hey Bansi Which state are you in? lodge a complaint with your State Building commission. Structural Serviceability defects should not be accepted in new builds. Cheers Chris These are most likely not serviceability defects. One could only know for sure after a detailed inspection. Lol, Mate, you're covering your mistakes like the gyprocker/painter , who incidentally aren't qualified to do detailed structural inspections. You must be from NSWs, where sadly, the Batters and punters have very little recourse for building defects.. unlike other states that have independent building commissions Here Builder collapse leaves apartment owners fearing alleged $30m defects Bill Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Plasterboard cracks - Builder responsibility 10Jan 21, 2021 11:51 am StructuralBIMGuy moudzj StructuralBIMGuy hey Bansi Which state are you in? lodge a complaint with your State Building commission. Structural Serviceability defects should not be accepted in new builds. Cheers Chris These are most likely not serviceability defects. One could only know for sure after a detailed inspection. Lol, Mate, you're covering your mistakes like the gyprocker/painter , who incidentally aren't qualified to do detailed structural inspections. You must be from NSWs, where sadly, the Batters and punters have very little recourse for building defects.. unlike other states that have independent building commissions Cheers Chris Maybe try actually reading my replies so you could first understand. Re: Plasterboard cracks - Builder responsibility 11Jan 21, 2021 11:55 am lol, Patch it up she'll be right Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Plasterboard cracks - Builder responsibility 12Jan 21, 2021 5:56 pm Thanks for the inputs. I have had the plaster person and the builder come and visit the damages. Some cracks in the wall were suggested as a settlement driven (movement) cracks. They reckon since the house is around 4 yrs old, it would have setup and hence good time to repair it. Apparently, a lot of houses have the cracks developing in the 1st 6 months aswell. Ofcourse all this is said by the builder which I can understand is being said as a defense. There was one issue they have agreed as an issue from their end and they have agreed to fix it. I will still need to cough up around 30% of the money. the conduit would need to be undamaged regardless of what network is in play. The conduit needs to be able to have fibre run through it. NBN and Opticomm are just… 4 3066 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 8554 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2874 |
