Browse Forums Building A New House Re: North Facing Property 11Jan 14, 2021 11:16 pm Hey mate, Very quickly cadded this up for you. Inbox me if youd like the .pdf files. Made some very obvious changes, and fixed a dimensional error you made with the rumpus. Changed benchtop dimensions to max ceaserstone slab size, walk room within kitchen, added doors (kind of), adjusted garage opening etc. Enjoy and goodluck. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: North Facing Property 12Jan 15, 2021 1:16 pm Hi Moudzj, You are a real champion, I think this image file will do for me. Would you recommend any alterations in the plan from the northerly aspect of the property? We would like to have 2 master ensuites, a big living space, small lounge at the front, and a small study space. Cheers!! Vineet The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18200 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19988 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16147 |
