Browse Forums Windows & Doors 1 Jan 14, 2021 12:04 am Since the build started and almost on completion. One of the big sliding door glass cracked 3 times that I noticed with. And the final stage with painting I don’t think the painters would crack it right? I did not see any tall ladder they are using. So I am now worried that it has problem of the installation and causing the cracks. My sliding door is recessed. But when they pour the slab, they forgot it. So they had to cut it back. I’m not sure if that’s where the problem is coming from. How can I find out? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Cracking sliding doors couple of times 2Jan 14, 2021 7:41 am Have you checked the deflection of the lintel above the door Frame? Start with the engineering drawings and make sure they have installed the correct lintel size and gap. Then check to see if the frame has distorted ,etc, etc, any loading causes the glass to crack Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Cracking sliding doors couple of times 3Jan 14, 2021 2:52 pm The head appears to sag, but if the door opens without rubbing then this is not the problem. Ask the supervisor he may know the reason. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Cracking sliding doors couple of times 4Jan 15, 2021 10:07 am ECOECO The head appears to sag, but if the door opens without rubbing then this is not the problem. Ask the supervisor he may know the reason. Alright, thanks. I will have a look. But the supervisor seems hopeless and doesn’t care much. Re: Cracking sliding doors couple of times 5Jan 15, 2021 10:16 am doro ECOECO The head appears to sag, but if the door opens without rubbing then this is not the problem. Ask the supervisor he may know the reason. Alright, thanks. I will have a look. But the supervisor seems hopeless and doesn’t care much. ask to speak to the building manager "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Cracking sliding doors couple of times 6Jan 16, 2021 1:00 am ECOECO doro ECOECO The head appears to sag, but if the door opens without rubbing then this is not the problem. Ask the supervisor he may know the reason. Alright, thanks. I will have a look. But the supervisor seems hopeless and doesn’t care much. ask to speak to the building manager Yes I will try to speak to the manager who is the owner. But if I get no where, who else I can go? Hi Minho I have heaps of experience in Ku-ring-gai with both DAs and CDC ( this is the main area we build in). DA's are taking 12-18months and CDC's we have been doing… 1 3209 1 6674 we have a standard size and often we have a lot of variety to choose 0 3626 |
