Browse Forums Building A New House Re: North Facing Property 3Jan 10, 2021 2:53 pm It seems that north is at the front of your property? In which case its not the ideal orientation, you want your back or living areas facing north, if your rear is south, then your front will be north. Re: North Facing Property 4Jan 10, 2021 8:43 pm Hillsbuilds Yes, you have contradicting requirements. However there are things you can do to get the north light into the back of your house. We have exactly the same issue, so we have a courtyard between the front and back of the house. Otherwise you could use skylights or clerestory windows. It really makes all the difference having north light in your living areas. Bear in mind also appropriate shading for summertime. Check out http://www.yourhome.gov.au, esp the passive design section. Thanks for your reply. We have been to the Display Homes and we really liked on the plans from Arden Homes which is Sienna 28. This one has a courtyard in between front and back of the house, as you suggested. We need to make few changes on this design to our requirements. Do you have a plan to share? Cheers!! Vin Re: North Facing Property 5Jan 11, 2021 10:16 am gogo65 It seems that north is at the front of your property? In which case its not the ideal orientation, you want your back or living areas facing north, if your rear is south, then your front will be north. Hi Gogo, Our property is north facing (front to north and rear to south). We would like to have the living areas at the rear (south). What are your suggestions about the plan? Re: North Facing Property 6Jan 11, 2021 9:51 pm Vineet Babbar Hillsbuilds Yes, you have contradicting requirements. However there are things you can do to get the north light into the back of your house. We have exactly the same issue, so we have a courtyard between the front and back of the house. Otherwise you could use skylights or clerestory windows. It really makes all the difference having north light in your living areas. Bear in mind also appropriate shading for summertime. Check out http://www.yourhome.gov.au, esp the passive design section. Thanks for your reply. We have been to the Display Homes and we really liked on the plans from Arden Homes which is Sienna 28. This one has a courtyard in between front and back of the house, as you suggested. We need to make few changes on this design to our requirements. Do you have a plan to share? Cheers!! Vin viewtopic.php?f=31&t=92728&hilit=Hamptons&p=1884705#p1884705 Re: North Facing Property 7Jan 12, 2021 9:38 pm Hi Vineet, north facing means back yard is facing north, so your block is south facing. In order to get the most out of your orientation, your living areas will need to be at the front or as suggested a plan with a courtyard that will allow northerly sun into the rear section of the house Re: North Facing Property 8Jan 13, 2021 8:53 pm I thought if you stand inside the house and look towards the front door and it faces North, the house orientation is said to be North facing. Re: North Facing Property 11Jan 14, 2021 11:16 pm Hey mate, Very quickly cadded this up for you. Inbox me if youd like the .pdf files. Made some very obvious changes, and fixed a dimensional error you made with the rumpus. Changed benchtop dimensions to max ceaserstone slab size, walk room within kitchen, added doors (kind of), adjusted garage opening etc. Enjoy and goodluck. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: North Facing Property 12Jan 15, 2021 1:16 pm Hi Moudzj, You are a real champion, I think this image file will do for me. Would you recommend any alterations in the plan from the northerly aspect of the property? We would like to have 2 master ensuites, a big living space, small lounge at the front, and a small study space. Cheers!! Vineet The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18203 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19991 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16148 |
