Browse Forums General Discussion Re: House not built to NATHERS 6 Star Energy Rating. 2Jan 02, 2021 4:04 pm Normally to get the building licence your building surveyor (certifier) will have to produce a CDC that includes an energy report based on the plans submitted. In order to supply a final certificate of completion the works have to match what the original CDC including energy report specifies. If it doesn't then the surveyor/certifier has failed to ensure the building is compliant. Are you sure this is what has happened? Did you use your own Surveyor? The thing that makes the biggest difference to a house is it's orientation. Even if a house has all the insulation and double glazing in the world if it gets direct sun in summer it will be hot. If it gets no sun in winter it will be cold. It kind of sounds like the orientation isn't great. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: House not built to NATHERS 6 Star Energy Rating. 3Jan 02, 2021 4:36 pm chippy Normally to get the building licence your building surveyor (certifier) will have to produce a CDC that includes an energy report based on the plans submitted. In order to supply a final certificate of completion the works have to match what the original CDC including energy report specifies. If it doesn't then the surveyor/certifier has failed to ensure the building is compliant. Are you sure this is what has happened? Did you use your own Surveyor? The thing that makes the biggest difference to a house is it's orientation. Even if a house has all the insulation and double glazing in the world if it gets direct sun in summer it will be hot. If it gets no sun in winter it will be cold. It kind of sounds like the orientation isn't great. The builder used their own building surveyor and inspector, they picked up on some issues but none of the major issues we face now. We sent off the report to another company for computer and thermal modeling and it doesn’t meet the minimum standard and the house is non compliant, being a volume builder I’m not sure what we can do but spend 10’s of thousands fighting it court. Re: House not built to NATHERS 6 Star Energy Rating. 4Jan 02, 2021 5:09 pm I imagine then that it is the responsibility of whoever produced the original energy report to show or give proofs as to how it complies and then the surveyor to confirm that it was constructed as per the energy report. The surveyor is responsible for the energy report and making sure the build is compliant. That's one reason the owner should use their own surveyor rather than relying on one provided by the builder. Ultimately it is the owners responsibility under law. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: House not built to NATHERS 6 Star Energy Rating. 5Jan 02, 2021 5:19 pm chippy I imagine then that it is the responsibility of whoever produced the original energy report to show or give proofs as to how it complies and then the surveyor to confirm that it was constructed as per the energy report. The surveyor is responsible for the energy report and making sure the build is compliant. That's one reason the owner should use their own surveyor rather than relying on one provided by the builder. Ultimately it is the owners responsibility under law. We will pass it all on and see what happens but being first time home builders I guess you shouldn’t put your faith in the builder doing the right or correct thing. Re: House not built to NATHERS 6 Star Energy Rating. 6Jan 02, 2021 7:37 pm You engage a builder to supply a product. Its the builders responsibility to provide a house that complies with the code, rules and regs regardless of who the surveyor is or plumber or eleco, other wise why would you pay builders margin and management costs when building a house if its no risk to the builder? Re: House not built to NATHERS 6 Star Energy Rating. 7Jan 04, 2021 8:19 pm Ardo You engage a builder to supply a product. Its the builders responsibility to provide a house that complies with the code, rules and regs regardless of who the surveyor is or plumber or eleco, other wise why would you pay builders margin and management costs when building a house if its no risk to the builder? There have been a lot of corners cut with out build and the rectification works are worse than the initial issue. Make some calls today to some NATHERS experts who have advised the house being non compliant and not built to code will need either substantial work or to be rebuilt. Re: House not built to NATHERS 6 Star Energy Rating. 8Feb 22, 2021 3:26 pm If your information is correct, then they have breached the contract and the house is not fit for purpose. Do you have a copy of their energy report? Can you send it to me? Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: House not built to NATHERS 6 Star Energy Rating. 9Feb 22, 2021 5:49 pm We had to fight to get a copy of it and eventually through council as the builder and building surveyor wouldn't supply a copy of it. We have has the report looked over and even though it's not accurate and doesn't show many areas of concern there are still discrepancies. The NATHers QR or report code isn't listed on the plans submitted to us or council and we have been advised that the builder will need to come in and re do the report and bring the house up to the 6 start minimum. Of course the builder is fighting everything even when we have proof they still fight it, mate you should see our slab, it's been classed as defective and they won't fix it. Re: House not built to NATHERS 6 Star Energy Rating. 10Feb 22, 2021 7:46 pm Thejones88 We had to fight to get a copy of it and eventually through council as the builder and building surveyor wouldn't supply a copy of it. We have has the report looked over and even though it's not accurate and doesn't show many areas of concern there are still discrepancies. The NATHers QR or report code isn't listed on the plans submitted to us or council and we have been advised that the builder will need to come in and re do the report and bring the house up to the 6 start minimum. Of course the builder is fighting everything even when we have proof they still fight it, mate you should see our slab, it's been classed as defective and they won't fix it. Pictures? How is it classified as defective? Re: House not built to NATHERS 6 Star Energy Rating. 11Feb 22, 2021 8:47 pm Fore2 Thejones88 We had to fight to get a copy of it and eventually through council as the builder and building surveyor wouldn't supply a copy of it. We have has the report looked over and even though it's not accurate and doesn't show many areas of concern there are still discrepancies. The NATHers QR or report code isn't listed on the plans submitted to us or council and we have been advised that the builder will need to come in and re do the report and bring the house up to the 6 start minimum. Of course the builder is fighting everything even when we have proof they still fight it, mate you should see our slab, it's been classed as defective and they won't fix it. Pictures? How is it classified as defective? I have a lot of pictures but we are looking to take things further and I will post some soon. We have a 45mm incline in to one room, alfresco appears to have a bore pier coming through the slab, site wasn't compacted after being back filled, slab not finished to Australian standards. 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 1459 Thanks for your reply! All valid points and I agree with you on many of them. I am in QLD, any recommendations on a construction lawyer would be helpful 3 2637 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110566 |
