Browse Forums General Discussion Re: Complying development approval help please 2Dec 27, 2020 6:41 am First, what state are you in? Second, it's depends what zone you're in, whether you have an relevant overlays or if the local council have triggers for building work. Most properties are exempt from requiring a DA because the primary use (as a house) is already approved. However, depending on the above you may have triggers which require additional building works to be assessed based on say, traditional character, overland flow or ecology etc ... So more info is required please. ๐ Follow Our Clarendon - Double Gable, Hamptonsย Inspired Fairmont 35 https://forum.homeone.com.au/viewtopic.php?f=31&t=94604 Re: Complying development approval help please 3Dec 27, 2020 8:09 am Rhetti First, what state are you in? Second, it's depends what zone you're in, whether you have an relevant overlays or if the local council have triggers for building work. Most properties are exempt from requiring a DA because the primary use (as a house) is already approved. However, depending on the above you may have triggers which require additional building works to be assessed based on say, traditional character, overland flow or ecology etc ... So more info is required please. ๐ Hi Rhetti, Thank you so much for your reply and apologies for the incomplete information. It's residential zone in Sydney south west area and family room area was approved to to build as extension/addition back in 2003 by previous owner. We are just renovating kitchen and bathroom etc so we decided to add small laundry plus one extra room for storage (previous owner added plumbing area there for some reason so plumbing was easy). I am super worry and don't know if I should stop the reno or continue. I honestly don't know what to do or who I should be contacting to rectify this matter. Thank you once again for your response ๐ Re: Complying development approval help please 4Mar 10, 2021 2:00 pm zyaree Rhetti First, what state are you in? Second, it's depends what zone you're in, whether you have an relevant overlays or if the local council have triggers for building work. Most properties are exempt from requiring a DA because the primary use (as a house) is already approved. However, depending on the above you may have triggers which require additional building works to be assessed based on say, traditional character, overland flow or ecology etc ... So more info is required please. ๐ Hi Rhetti, Thank you so much for your reply and apologies for the incomplete information. It's residential zone in Sydney south west area and family room area was approved to to build as extension/addition back in 2003 by previous owner. We are just renovating kitchen and bathroom etc so we decided to add small laundry plus one extra room for storage (previous owner added plumbing area there for some reason so plumbing was easy). I am super worry and don't know if I should stop the reno or continue. I honestly don't know what to do or who I should be contacting to rectify this matter. Thank you once again for your response ๐ your builder could be correct. You are allowed to build a storage room as an exempt development ( similar to a storage garden shed) I think the limit is 15sqm but could be wrong. Best to call a private certifier in your area Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Complying development approval help please 5Mar 10, 2021 2:00 pm zyaree Rhetti First, what state are you in? Second, it's depends what zone you're in, whether you have an relevant overlays or if the local council have triggers for building work. Most properties are exempt from requiring a DA because the primary use (as a house) is already approved. However, depending on the above you may have triggers which require additional building works to be assessed based on say, traditional character, overland flow or ecology etc ... So more info is required please. ๐ Hi Rhetti, Thank you so much for your reply and apologies for the incomplete information. It's residential zone in Sydney south west area and family room area was approved to to build as extension/addition back in 2003 by previous owner. We are just renovating kitchen and bathroom etc so we decided to add small laundry plus one extra room for storage (previous owner added plumbing area there for some reason so plumbing was easy). I am super worry and don't know if I should stop the reno or continue. I honestly don't know what to do or who I should be contacting to rectify this matter. Thank you once again for your response ๐ your builder could be correct. You are allowed to build a storage room as an exempt development ( similar to a storage garden shed) I think the limit is 15sqm but could be wrong. Best to call a private certifier in your area Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5570 Hi, does anyone have a clue how the Brisbane Development website work in terms of how uptodate the dates on it are (developmenti.brisbane.qld.gov.au). I transfered… 0 4685 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6507 |
