Browse Forums Windows & Doors Re: Sliding window panel removal 2Dec 01, 2020 12:56 pm butters7388 Having issues with our sliding window panels. We built about 3 years ago, and have never been able to get the sliding panel from our windows out easily. The panel does not lift high enough for the wheels to clear the bottom frame rail. Has anyone else had this issue? It is on all windows, not just one of them.....window company say it is a builder issue. There should be a security feature on the head of the window to prevent the sash from being lifted out. This is called an anti-lift device. open the window and check inside the head... it should be a plastic block screwed in. Remember to replace it... "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Sliding window panel removal 3Dec 06, 2020 8:38 am ECOECO butters7388 Having issues with our sliding window panels. We built about 3 years ago, and have never been able to get the sliding panel from our windows out easily. The panel does not lift high enough for the wheels to clear the bottom frame rail. Has anyone else had this issue? It is on all windows, not just one of them.....window company say it is a builder issue. There should be a security feature on the head of the window to prevent the sash from being lifted out. This is called an anti-lift device. open the window and check inside the head... it should be a plastic block screwed in. Remember to replace it... Nothing like that on these windows unfortunately Re: Sliding window panel removal 4Dec 07, 2020 10:04 am butters7388 ECOECO butters7388 Having issues with our sliding window panels. We built about 3 years ago, and have never been able to get the sliding panel from our windows out easily. The panel does not lift high enough for the wheels to clear the bottom frame rail. Has anyone else had this issue? It is on all windows, not just one of them.....window company say it is a builder issue. There should be a security feature on the head of the window to prevent the sash from being lifted out. This is called an anti-lift device. open the window and check inside the head... it should be a plastic block screwed in. Remember to replace it... Nothing like that on these windows unfortunately Ask the window company to explain how they are taken out. If they won't come out that way then it's a problem for your builder to solve with the supplier. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6487 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6849 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10359 |
