Browse Forums General Discussion Re: Would you lose a bedroom to gain more living space? 3Nov 20, 2020 12:40 pm bestspecials Thedot Hi all. We built a four bedroom home 4 years ago but it was our first time and in hindsight I don’t feel like our main living space is big enough. At the time we thought we wanted 3 children but we are pretty content with 2. I’ve been thinking of knocking down a wall and converting the fourth bedroom into extra living space, which would also bring in some more natural light into our kitchen. But I’m nervous that it’s a bad decision because it would make our house a three bedder. I don’t think we have plans to sell anytime soon but it still makes me nervous. What would you do? Any advice or tips? Do you have a plan of the house? It is a McDonald Jones Manhattan One. Considering knocking down the wall of bedroom 4 that adjoins the kitchen/living area. Re: Would you lose a bedroom to gain more living space? 4Nov 20, 2020 7:12 pm " It is a McDonald Jones Manhattan One. Considering knocking down the wall of bedroom 4 that adjoins the kitchen/living area." And without seeing a floorpan, we have no idea what would be the best course of action... Stewie Re: Would you lose a bedroom to gain more living space? 6Nov 21, 2020 9:17 am Resale will be better with 4 bedrooms than 3. Do you want more living space outside or inside? Do you need a home office? You've got a home theatre room. Do you really need that? The typical bulk builders "Home Theatre Room" doesn't come with the acoustic insulation etc that would make it anything like a theatre environment. Convert that to your 4th bedroom and enlarge your living space by doing away with Bedroom 4 at the back? Set the 4th bedroom up so it can be used as a home office. Re: Would you lose a bedroom to gain more living space? 7Nov 21, 2020 10:16 am Althom Resale will be better with 4 bedrooms than 3. Do you want more living space outside or inside? Do you need a home office? You've got a home theatre room. Do you really need that? The typical bulk builders "Home Theatre Room" doesn't come with the acoustic insulation etc that would make it anything like a theatre environment. Convert that to your 4th bedroom and enlarge your living space by doing away with Bedroom 4 at the back? Set the 4th bedroom up so it can be used as a home office. We plan on staying here long term so resale isn’t a big issue for us. I’ve thought maybe we could convert the home theatre to a bedroom if we ever were to sell. We are wanting extra inside living space.. Re: Would you lose a bedroom to gain more living space? 9Nov 21, 2020 11:44 am How would you use that space if you did knock that wall out? Althom's idea is a good addition seeing as you don't have a dedicated home office. Stewie Re: Would you lose a bedroom to gain more living space? 10Nov 23, 2020 10:49 am Can I make a suggestion - the Manhattan Two plan would be a better option Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The media room is already in the right place. If you flip the orientation of the room and putter double cavity sliders on the door, you will get the extra light you are looking for by leaving the doors open when you aren't using the room. It could also have direct access to the outdoor area via external sliders. That leaves bedrooms one and three with direct access to the 2nd bathroom and bedroom 2 could then be used as a multi-purpose room (guest room, play room or study). Re: Would you lose a bedroom to gain more living space? 11Nov 23, 2020 1:49 pm bestspecials Can I make a suggestion - the Manhattan Two plan would be a better option Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The media room is already in the right place. If you flip the orientation of the room and putter double cavity sliders on the door, you will get the extra light you are looking for by leaving the doors open when you aren't using the room. It could also have direct access to the outdoor area via external sliders. That leaves bedrooms one and three with direct access to the 2nd bathroom and bedroom 2 could then be used as a multi-purpose room (guest room, play room or study). Great suggestion except we have already built and just looking at how we could make adjustments. In hindsight I would have gone with the Two over the One. But yes, this floor plan is essentially what we would end up turning our Manhattan One into. Good idea on the cavity sliders, I hadn’t thought of that Re: Would you lose a bedroom to gain more living space? 12Dec 01, 2020 2:47 pm One thing to consider is if you use the Home Theatre as a bedroom then you no longer have two separate living areas. This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 11117 I would be wary. Is you site demilished but nothing else done? Sounds like liquidity problems to me. Our builder did the same. Got hundreds of thousands of dollars of… 2 15586 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8876 |
