Browse Forums Outdoor Living 1 Nov 12, 2020 7:49 am Hi all, We are in the final stages of construction and didn't include any tiling/decking on the rear outdoor area and I think I'm regretting not having it included. While I am going to organise something after handover, I'm interested in how it should come together since it's raised with the exposed top of the external bricks with the gap between the slab. If I was to tile the area, what's the best way to fill that gap and go to the end of the brick? Also, wouldn't a railing be a challenge to fix to the floor over those bricks with holes? Would love to hear thoughts of others that have similar. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Raised alfresco on slab 2Dec 02, 2020 7:22 am I'd be asking the building why the slab doesn't cover the bricks and go to the edge fo the building footprint. There also appears to be some rubbish in the gap. To put a surface over the area and cover the gap you could use timber battens and decking or composite decking. Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4270 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 5124 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1855 |
