Browse Forums General Discussion Re: Cornice on load bearing wall cracked every 600mm or so. 3Nov 08, 2020 10:10 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Cornice on load bearing wall cracked every 600mm or so. 9Nov 11, 2020 5:40 pm alexp79 This sounds like a slab heave issue to begin with, roof trusses providing load on a non-load bearing wall is just a consequence. Yes most likely but if one side of the house has subsided it will have same effect. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18731 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 11601 4 7039 |
