Browse Forums Landscape & Garden Design Re: Concrete advice 2Oct 20, 2020 8:37 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Concrete advice 4Oct 21, 2020 7:46 am Hey everhopeful Welcome back to the forum There appears to be a number of issues I do recommend you use a Bosch Concrete Scanner here Bosch D-Tect 150 SV Scanner to determine the reinforcement placement depth Pity you didn't have the job inspected and photographed before the concrete was poured. Over time the cracking will get worse and eventually the concrete will spall when the mesh rusts....certainly not acceptable by any standards Things that can effect your driveway build are 1.The soil type 2.Compaction 3.Soil moisture and weather conditions 4.Concrete thickness 5.Reinforcement Placement 6.Poor workmanship and concrete mix 7.Insufficent workers on site during the pour 8.Lack of technical data and specifications Concrete is one of those items that needs to be properly inspected the ability to rectify problems while the concrete truck is waiting is minimal Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concrete advice 5Oct 21, 2020 8:10 am StructuralBIMGuy Hey everhopeful Welcome back to the forum There appears to be a number of issues I do recommend you use a Bosch Concrete Scanner here Bosch D-Tect 150 SV Scanner to determine the reinforcement placement depth Pity you didn't have the job inspected and photographed before the concrete was poured. Over time the cracking will get worse and eventually the concrete will spall when the mesh rusts....certainly not acceptable by any standards Things that can effect your driveway build are 1.The soil type 2.Compaction 3.Soil moisture and weather conditions 4.Concrete thickness 5.Reinforcement Placement 6.Poor workmanship and concrete mix 7.Insufficent workers on site during the pour 8.Lack of technical data and specifications Concrete is one of those items that needs to be properly inspected the ability to rectify problems while the concrete truck is waiting is minimal Cheers Chris Thanks structuralbimguy hopefully it helps that this is a pathway so will only have foot traffic or am I clutching a straws? I have attached a photo, from down the side, which is also has hairline cracks, to provide context [img]https://forum.homeone.com.au/u/83674_1603231767.jpeg[/i Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12527 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18149 |
