Browse Forums Building A New House 1 Oct 20, 2020 3:17 pm Hi All, It might sound silly but I really want to get to know any idea or trick to be able to visualize the size of a room by knowing the size. For example if someone says would you like to have room of 2m x 4m, I am unable to guess the realistic size of the room, like would it be as big as a bathroom, or a laundry , etc..is there a trick to learn this? Please help as I am doing my house project all by myself and have been doing my home work but this is the one I really need to get over. Thank you, Re: Room size 2Oct 20, 2020 3:24 pm Compare it against the rooms of your current house? Or go out to an oval and tape it out to scale with masking tape. Re: Room size 3Oct 20, 2020 3:39 pm Yeah kind of a hard one to answer as there are no "standard" sizes for bathroom or laundry's. Like Hillsbuilds said, get yourself a tape measure and check the size of the rooms of your house or take a tape measure to display homes and measure the rooms in them to see how they compare to what you're thinking. Follow my build here: https://www.instagram.com/ivy5custom Re: Room size 4Oct 21, 2020 7:36 am Hi guys, Thank you for the idea. I have already tried it. The problem for me occurs, not really when I have visualize 1 room (approximately). It happens when I have to visualize all the rooms together and imagine how big the plan will be, or how small it should be, or even that how small or big it will look if there is a + or - of few meters.. Please help. Thank you, Re: Room size 5Oct 24, 2020 6:44 am nyk156 Hi guys, Thank you for the idea. I have already tried it. The problem for me occurs, not really when I have visualize 1 room (approximately). It happens when I have to visualize all the rooms together and imagine how big the plan will be, or how small it should be, or even that how small or big it will look if there is a + or - of few meters.. Please help. Thank you, post your plan showing approx dimensions and direction of north and i can draw up a rough plan that can show the size of the whole house and individual rooms and then make adjustments to increase or reduce Re: Room size 6Oct 24, 2020 7:13 am https://onetoonedisplays.com.au/offer/ Walk through your home in real life scale before you build. Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3665 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3548 |
