Browse Forums Building A New House Re: How over engineered are timber framed homes?? 4Oct 20, 2020 11:20 am Greenroom Hmm yes that is a good point. Unfortunately all of the existing plans went up in literal flames when the councils store burned down in the 1990's and all permits were lost. How could I gauge the existing footings without cutting chunks out of them to see the sections? you're not in bankstown are you? i remember the council burning down in the 90's, was amazing to watch. If I remember correctly a spark from a dude welding some air conditioning pipes. if you are in sydney I can give you the number of a great structural engineer who can give you some advice Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: How over engineered are timber framed homes?? 6Oct 20, 2020 1:04 pm Hey greenroom I think you'll find your House is under engineered and the codes would have changed, so your renovation design and engineering will need to be brought up to date and certified. To determine the footing size & depth you can drill holes or have the slab scanned (x-rayed). The latter is expensive Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15886 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6113 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 |
