Browse Forums Windows & Doors Re: Window replacement, pls help! 5Oct 14, 2020 2:55 pm I am fairly sure the problem is the Juliet Balcony which is unsealed... share some pics. Thanks "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Window replacement, pls help! 6Oct 20, 2020 5:15 pm Hi ECOECO, thx for the reply! What you're seeing there are just some temporary interventions I made to keep as much water as possible from draining into the substructure. I've attached some plastic ledges to the 2 centre window panes so that the water that hits the glass shoots off those and onto the polycarbonate sheets that I've temporarily installed at an incline on top of the Juliet balcony Re: Window replacement, pls help! 7Oct 21, 2020 9:27 am CJay77 Hi ECOECO, thx for the reply! What you're seeing there are just some temporary interventions I made to keep as much water as possible from draining into the substructure. I've attached some plastic ledges to the 2 centre window panes so that the water that hits the glass shoots off those and onto the polycarbonate sheets that I've temporarily installed at an incline on top of the Juliet balcony I'd put my money on the balcony being the problem. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 2 2317 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7223 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45790 |
