Browse Forums DIY, Home Maintenance & Repair Re: Sorting out Drainage 2Aug 06, 2019 11:50 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Sorting out Drainage 4Aug 13, 2019 8:26 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Sorting out Drainage 6Sep 30, 2020 1:51 pm A silt pit's purpose is to trap silt before the water connects to the stormwater system, it is a regulatory requirement. You should ask a qualified drainer to attend on site and discuss with him. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 2 6161 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3270 13 6876 |
