Browse Forums Owner Builder Forum 1 Sep 27, 2020 9:25 am Hi All I've been searching through the web for cable balustrade systems and there appears to be some simple, and some more complex options. My issue is that I have 5mm hot-dip gal posts and I'm desperately trying to avoid having to drill a million holes for all my cable saddles. It will take an eternity. I'm looking for a welding option where the cable end fittings can be welded to my steel post. Those saddles look too thin to weld. Does anyone have any ideas how to use a cable balustrade system with welding instead of screwing saddles to the steel posts? Re: Cable deck balustrade with steel posts 2Oct 23, 2020 7:06 am Rozz Hi All I've been searching through the web for cable balustrade systems and there appears to be some simple, and some more complex options. My issue is that I have 5mm hot-dip gal posts and I'm desperately trying to avoid having to drill a million holes for all my cable saddles. It will take an eternity. I'm looking for a welding option where the cable end fittings can be welded to my steel post. Those saddles look too thin to weld. Does anyone have any ideas how to use a cable balustrade system with welding instead of screwing saddles to the steel posts? This would give a professional looking finish. Use duralac on the eye bolt threads to minimise galvanic corrosion Re: Cable deck balustrade with steel posts 4Oct 23, 2020 7:37 pm Pulse use a nutsert, an internally threaded rivet and screw the stainless swagged wire in Betterhardware.com.au do a flip toggle where you can just drill a hole... Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14574 Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9136 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7136 |
