Browse Forums Eco Living 1 Dec 26, 2016 10:36 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Washing machines and environmental vandalism 2Sep 04, 2018 11:13 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Washing machines and environmental vandalism 8Sep 18, 2020 11:08 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Washing machines and environmental vandalism 9Sep 18, 2020 11:29 am SaveH2O Grey water needs to be used fairly quickly as it can't be stored for more than 24 hours. You also need to pay attention to the laundry detergent composition before using it on the garden and it is best to only use the final rinse. It would require a very fine filter to capture plastic fibres. Of interest, micro plastics have recently been found in 100% of human organs tested in 47 deceased persons. We are what we eat. https://www.greenmatters.com/p/micropla ... man-organs https://www.sciencedaily.com/releases/2 ... 104325.htm Should I consult a permaculture or gardening specialist to see any soil impacts on fibres in the garden? We currently manually collect buckets each was cycle and run them out to a reed bed or straight to the fruit trees. We use eco store detergent and add nutrients to the trees periodically. We collect water from the entire wash cycle. The trees have been doing well using this process but I never considered fibres. Re: Washing machines and environmental vandalism 10Sep 18, 2020 11:51 am Google would be your friend here. There are numerous studies concentrating on the amount of micro plastics in the food chain, the air we breathe and even the amount that falls on our water supplies that makes it to our taps! Humans are becoming the plastic fantastic. https://www.abc.net.au/triplej/programs ... s/11436168 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Washing machines and environmental vandalism 11Sep 18, 2020 12:25 pm SaveH2O Google would be your friend here. There are numerous studies concentrating on the amount of micro plastics in the food chain, the air we breathe and even the amount that falls on our water supplies that makes it to our taps! Humans are becoming the plastic fantastic. https://www.abc.net.au/triplej/programs ... s/11436168 Thank you 1 4695 Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17520 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10031 |
