Browse Forums General Discussion Re: Typical cost per sqm for high-performance/passivhaus hom 7Sep 14, 2020 2:15 am Passivhaus will be nearly impossible to achieve with standard timber frame construction. It will be extremely hard to seal the timber framed house completely as due to moisture and temperature changes as well as house settlement, timber frame will still be having certain degree of movement and therefore will still be creating air gaps. If your builder never built passivhaus and (probably) has no idea what it involves, you better look for the custom builder with experience. Re: Typical cost per sqm for high-performance/passivhaus hom 8Sep 14, 2020 8:47 am I built a solar passive house. The inside walls are brick to store the heat overnight and the exterior walls are insulated timber frame to minimize heat loss/gain. The eaves overhang was calculated to provide shading during summer but still allow solar heat gain during winter. Hi We are building in the Hunter Valley, our soil test is H1, our builder has advised us they need to have a letter signed for Fair Trading as the new drainage standard… 0 3561 Petercurtis You able to contact the certifier and get a copy of your structural plans, if they are not in your contract. If your home was approved via CDC then they… 1 20187 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3729 |
