Browse Forums Building A New House Re: Design and orientation - advice appreciated 4Sep 12, 2020 4:54 pm realjian Hi, Advice sought: - Thoughts on the design/orientation? (Pic Below) the front is facing north. - general feedback of anything you think is relevant! I have recently decided to build in the new suburb in Canberra and am choosing custom building using an architect. I'm a first time home builder and have read a whole bunch of forums with a heap of useful advice, so would appreciate it if you could provide any of your thoughts on the below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ my suggestion include adding furniture to help suggest ideal door and window locations and you need to lose the extra doorway through the kitchen and pantry, add a handbasin in the upstairs loo, consider Solar skylights for kitchen, hallways and all windowless rooms (checkout Arcol and illume brands for more detail) and there's new outside step .. without all the dimensions my room sizes are estimated but minor upstairs changes should save a few extra metres and still allow some changes for added comfort eg master toilet removed from next to the bed, under stairs storage in the laundry, bigger windows and more wall space at the front of the house...and consider a closeable door at the top or bottom of the stairs and across teh entry hall for better temp and draught control Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Design and orientation - advice appreciated 5Sep 12, 2020 10:40 pm oklouise realjian Hi, Advice sought: - Thoughts on the design/orientation? (Pic Below) the front is facing north. - general feedback of anything you think is relevant! I have recently decided to build in the new suburb in Canberra and am choosing custom building using an architect. I'm a first time home builder and have read a whole bunch of forums with a heap of useful advice, so would appreciate it if you could provide any of your thoughts on the below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ my suggestion include adding furniture to help suggest ideal door and window locations and you need to lose the extra doorway through the kitchen and pantry, add a handbasin in the upstairs loo, consider Solar skylights for kitchen, hallways and all windowless rooms (checkout Arcol and illume brands for more detail) and there's new outside step .. without all the dimensions my room sizes are estimated but minor upstairs changes should save a few extra metres and still allow some changes for added comfort eg master toilet removed from next to the bed, under stairs storage in the laundry, bigger windows and more wall space at the front of the house...and consider a closeable door at the top or bottom of the stairs and across teh entry hall for better temp and draught control Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Some really great ideas which we will talk to the architect about. Thanks a lot 0 654 Hi, My first post here. I got an plot of land that is at an angle to the road & facing South-East. I read a planning guide on house orientation and the attached layout… 0 538 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 19107 |
