Browse Forums Building A New House Re: Is my potential double garage build too small? 5May 28, 2019 8:47 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Is my potential double garage build too small? 15May 28, 2019 4:33 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Is my potential double garage build too small? 17Sep 04, 2020 8:25 pm [quote="Bobjane":dwhsl0if]You guys mentioned 4.8m is the standard garage door width, however should i get a 5m wide garage door since the garage will now be 6m wide? any thoughts?[/quote:dwhsl0if] Where did you end up with on the garage door width. Our garage in our planned build is also 6.0 wide by 6.5 deep and our plans show a 4800 wide door. Thinking this needs to be wider but don't have any experience with double doors to base this off. Also curious to how it will look visually. Follow my build here: https://www.instagram.com/ivy5custom Re: Is my potential double garage build too small? 19Sep 04, 2020 9:05 pm Pulse 4.8m door is ok for a nice straight driveway, if you need to swing in at all an extra 300mm will really help Thanks. We have the room and capacity to widen the door but also don't want to do it of 4.8 is more than enough. We aren't a perfectly straight driveway but I don't think we'd have much issue with needing to swing in at all. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Follow my build here: https://www.instagram.com/ivy5custom Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2673 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8233 Just removed 40 liters of water in the span of 2 hours. Water fills up the hole just above the seepage point and doesn't overflow. 1 960 |
