Browse Forums General Discussion Re: Concrete path around house 2Mar 10, 2013 12:26 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Concrete path around house 6Mar 10, 2013 1:03 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Concrete path around house 8Mar 10, 2013 1:25 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Concrete path around house 10Mar 10, 2013 4:33 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Concrete path around house 13Mar 10, 2013 6:04 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Concrete path around house 14Mar 11, 2013 5:24 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Concrete path around house 15Mar 11, 2013 10:02 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Concrete path around house 17Mar 11, 2013 11:01 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Concrete path around house 18Mar 11, 2013 1:50 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Concrete path around house 19Sep 04, 2020 3:02 am building-expert As qualified and accredited timber pest inspector I can tell you that the simplest and effective non chemical method is to have 75mm slab exposed around dwelling as inspection zone (as Stewie mentioned ) but for some inexplicable reason it is not done in VIC. We prefer to pump toxins into our environment. One million homes= lot of chemicals x retreatment every 5-7 years. Want definition of insanity? You have got it! Is this still preferred? 75mm of slab exposed from the finished heigh of concrete footpath? And concrete footpath is 50mm of compacted roadbase + 100mm concrete slab? Did I get the right? 225mm in total from The base of the bottom bricks. Sorry just need to know. We have excavated 175mm below my first bricks to prepare for a concrete footpath. Just wondering if I have excavated too much? Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12986 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8634 Thank you so much for your response. I have drawn a pedestrian gate in - for curb appeal, let's see how much costs come in at. I think you're right - if we decide to… 2 6584 |
