Browse Forums Landscape & Garden Design 1 Sep 02, 2020 9:49 am Put a layer of dromana toppings (40mm) on top of a well compacted base (75mm) of crushed rock. Damped down the toppings very lightly before using a plate compactor. Brushed off as much of the ridges caused by the compactor as possible but these still show and I'm not happy with the overall finish. How can I smooth these ridges out of the toppings? Can I run a compactor over the toppings once they've dried out and hardened? Do I need to damp them down again before compacting again? Any help or advice on the best way get a much smoother surface would be great. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10009 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6177 1 13153 |
