Browse Forums Bathrooms and Laundry Re: Fixing Villa Board/Cement sheeting in wet area 9Sep 01, 2020 5:48 pm Hi, I have been reading a few of these posts regarding Aquacheck and Villaboard for the bathroom. I recently had our waterproofing fail in our bathroom - house is 10 years old (Qld). Every tiler, builder etc. that have been to quote have said that they should never have used Aquacheck and it should always be Villaboard. I have read the posts so I know that there is a difference of opinion amongst people and that is fine. I am now in a situation where I want to keep most of the Aquacheck in the areas of the bathroom where the sheeting hasn't needed to be removed. I want to sheet around the shower with Villaboard but then I am going to have a 3mm difference in sheeting thickness. Has anyone seen this done successfully? The tiler said he wanted to ensure the tiling went over the join between the villaboard and the aquacheck but I am concerned I will wind up with an ugly renovation or worse - back in a situation with another waterproofing fail. If I just use Villaboard on the entire 2 walls that the shower (corner shower) backs onto and leave the other 2 walls with Aquacheck - will you be able to tell the difference after painting? Thanks T DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3171 Hi all. I'm thinking of installing an electric gate in front of this street front villa (link below). The gate would be between the bush on the left and the letter box on… 0 2781 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5421 |
