Browse Forums Kitchen Corner Re: How to hide joins on rear panels of kitchen island? 2Aug 31, 2020 3:22 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How to hide joins on rear panels of kitchen island? 4Aug 31, 2020 6:50 pm They are just back panels the same as you have side panels. Is this a flat pack? You are just over sheet size to do it in one sheet unless it happens to be available in oversized sheets. Normally we build kitchens with multiple pieces on the back because it's more economical, simpler to transport and fix. All the panels are edged 3 sides (bottom and 2 sides). It wasn't the kicker or toe space I was asking it's the gap below the kickboard. It looks like a 5mm gap between the floor and the kickboard. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: How to hide joins on rear panels of kitchen island? 5Aug 31, 2020 9:46 pm chippy They are just back panels the same as you have side panels. Is this a flat pack? You are just over sheet size to do it in one sheet unless it happens to be available in oversized sheets. Normally we build kitchens with multiple pieces on the back because it's more economical, simpler to transport and fix. All the panels are edged 3 sides (bottom and 2 sides). It wasn't the kicker or toe space I was asking it's the gap below the kickboard. It looks like a 5mm gap between the floor and the kickboard. It's an Ikea kitchen with a few variations, so yes, flatpack (limited budget). The panels I have were left overs from something else, including the sides that by fit by size but I guess won't work because of the cuts. It's looking more like I'll just need to fork out for the right size pieces. I'd just loose fit all the panels and the kickboard so the gap is bigger than it really is, it just needs to slide down. Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8451 Hello - we were hoping to apply laminate click lock panels to our concrete ceiling, but not too sure how to go about attaching the panels to the concrete. Any idea what… 0 1679 |
