Browse Forums General Discussion Re: Thud (knock) noise coming from area between ceiling and 4Sep 03, 2019 11:32 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Thud (knock) noise coming from area between ceiling and 6Sep 04, 2019 10:38 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Thud (knock) noise coming from area between ceiling and 8Sep 06, 2019 9:54 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Thud (knock) noise coming from area between ceiling and 9Aug 31, 2020 9:28 am Daven, I have the exact same issue!!! It is so hard to explain it to others but I’m glad you have! We have just moved to a new apartment block and have the same knocking sounds since we moved in. It has gotten worse week after week. The builders guys are around and trying to identify the issue however are still scratching their heads! Have you had any progress in identifying your source? Thanks, Mandar Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 Chemtrails, only the most disproven conspiracy theory in the history of conspiracy theories. You've gone in the deep end, drowned, and are now a mindless bloated… 5 86569 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38444 |
