Browse Forums Windows & Doors Re: Which seal to use? 7Aug 10, 2020 3:16 pm ECOECO I understand. No sill flap, are these new windows? Are the drain holes under the sill or at the front of the sill? The window could have been set further forward to close the gap to the bricks - is this an option? Re: Which seal to use? 8Aug 10, 2020 3:30 pm So the job is to close the gap from bricks to sill. To be honest, the windows don't suit the opening, and should have been measured to set them further forward particularly because this window has an offset reveal. Plus an inline reveal would have left no gap. Let me think and come back. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Which seal to use? 10Aug 12, 2020 3:25 pm In short, there would be no gap, except for say 5mm planned for caulking. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Which seal to use? 11Aug 12, 2020 4:45 pm These were new windows retrofitted in an old house. There is render below the reveals which means the outer bricks are lower than the inner bricks thus the gaps. And older brick works weren't perfect either. Re: Which seal to use? 12Aug 13, 2020 11:49 am I know the problem. We install our replacement windows in lots of different building-in situations. This could have been done differently with a better result. The fix will be a compromise. Maybe an aluminium box section all round would look like it's a single product rather than a fix-up. Then caulk the section especially at the sill, but be careful not to cover the drain holes. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5200 4 14302 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17888 |
