Browse Forums Buying Land Re: Is it fine to buy a lot which has engineered depth fill 7Aug 05, 2020 1:59 pm ![]() Are you missing a decimal point....? The only way it will impact the building is through poor design of the footings and slab. Providing that doesn't happen it shouldn't have any bearing on any insurance costs on policies. I could be wrong but I've never heard of it being mentioned before. Generally, the only thing which affects resale value would be if the structural design was lacking and the building showed signs of distress-which it shouldn't if done properly. Make sure you get a decent geotech-the minimum requirement to fulfil the building regs will be of no use, it will (or should) tell you its a P site and a 'deep' footing system is required and look to minimise those costs upfront. Be aware that compacted clay fill has an increased potential for shrink-swell movements compared to the same soil in a natural condition. so if can't prevent soil from moving, let the whole house moving together with it? 600mm is standard large cabinet depth. Standard depths are 600, 450 and 300 depth for overheads. Trust me, maintain a pantry in even 600m cupboards is a PITA. It sounds… 1 6072 11 2021 I think I have a mental picture of what you are trying to do and I think you could achieve floating shelves with an unconventional approach and some effect. If you could… 3 1484 |
