Browse Forums Building A New House Re: Electric meter pipe and water tap pipe too close to each 2Aug 03, 2020 7:09 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric meter pipe and water tap pipe too close to each 4Aug 03, 2020 7:19 pm Query it. If nothing else, it will show them that you are on your toes and aware of the regs. Are you using a well qualified building consultant for stage inspections? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric meter pipe and water tap pipe too close to each 5Aug 05, 2020 6:55 am SaveH2O Query it. If nothing else, it will show them that you are on your toes and aware of the regs. Are you using a well qualified building consultant for stage inspections? Thanks so much. I am using a independent building consultant for each stage. I did ask him he thinks it’s ok. But that was already after bricks were put in. I was just concerned that the pipes were overlapping each other. But it seems like it’s ok Re: Electric meter pipe and water tap pipe too close to each 6Aug 05, 2020 7:09 am It could have been a lot neater and a sparkie might have a stronger view. Try posting the same Q in the Whirlpool Forums Home Lounge, there are lots of sparkies on there. To upload a photo on WP, you need to... Register account with Imgur and log in. Click on add images Drag & drop photo into box to upload. Open your uploaded image. Copy image link from list of right side of page. (you want "direct link") Paste link into your WP thread. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. put the 2 draw set directly under the cooktop and the 3 draw set either side for balance 1 1184 For our new build in NSW we opted for a heat pump with a 315L storage tank. Early days yet as we only moved in 6 weeks ago. Haven't run out out of hot water though. Ours… 7 4372 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1876 |
