Browse Forums Building A New House 1 Aug 03, 2020 6:27 pm Hi I am not sure if they are too close or not, they have laid the bricks already so I hope it’s okay? Does anyone know the regulation with this? I’m just worried if the water tap breaks or the pipes then might have live electricity or something? Anyone who has knowledge on this can share please? Thanks
Re: Electric meter pipe and water tap pipe too close to each 2Aug 03, 2020 7:09 pm As per AS/NZS 3500.1 Section 5.3 Proximity to other services. Above ground separation of at least 25mm shall be maintained between a water service and any of the following services: Electrical conduit. Electrical wire or cable. Consumer gas pipes. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric meter pipe and water tap pipe too close to each 3Aug 03, 2020 7:15 pm SaveH2O As per AS/NZS 3500.1 Section 5.3 Proximity to other services. Above ground separation of at least 25mm shall be maintained between a water service and any of the following services: Electrical conduit. Electrical wire or cable. Consumer gas pipes. Hi SaveH2O, Thanks for replying. I did measure it, it looks like it’s about 25mm. Did I understand it correctly? Does it means it’s ok? Thank you Re: Electric meter pipe and water tap pipe too close to each 4Aug 03, 2020 7:19 pm Query it. If nothing else, it will show them that you are on your toes and aware of the regs. Are you using a well qualified building consultant for stage inspections? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric meter pipe and water tap pipe too close to each 5Aug 05, 2020 6:55 am SaveH2O Query it. If nothing else, it will show them that you are on your toes and aware of the regs. Are you using a well qualified building consultant for stage inspections? Thanks so much. I am using a independent building consultant for each stage. I did ask him he thinks it’s ok. But that was already after bricks were put in. I was just concerned that the pipes were overlapping each other. But it seems like it’s ok Re: Electric meter pipe and water tap pipe too close to each 6Aug 05, 2020 7:09 am It could have been a lot neater and a sparkie might have a stronger view. Try posting the same Q in the Whirlpool Forums Home Lounge, there are lots of sparkies on there. To upload a photo on WP, you need to... Register account with Imgur and log in. Click on add images Drag & drop photo into box to upload. Open your uploaded image. Copy image link from list of right side of page. (you want "direct link") Paste link into your WP thread. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Not unless you have managed to put it as a special condition into the contract somehow. 1 6155 Thanks good to know. How big is your tank? So you can set when your heat pump runs? How do you do that? How's the speed to heat? Is there such thing as instantaneous… 4 885 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1669 |
