Browse Forums Building A New House Re: New Build - Bushmead Estate, WA 4Aug 03, 2020 11:58 am Depends on your situation, if you’ve got three kids or planning on having in the future I’d leave it as 3 similar sized bedrooms. If this is your forever home then do what works. Also would depend on the area is a four bedroom home more sort after therefore paying a much higher premium than a 3 plus study? Ideally I would of added and additional 500mm to the length of the house(bedroom side) and made the bedrooms are bit more spacious, allowing for 3 reasonable sized bedrooms. Although the bedrooms say they are 4030 x2980, in reality they are 3300x2980 as the wardrobe takes up 700mm of that space. Just one other comment if I may....I’m not sure why builders still have glass sliding doors in laundries, all they achieve is an area between bench or washing machine and the glass, a moist dust catcher, if you can put a glass normal opening door on there, it will allow you to run cabinetry all the way to the wall. Also just make sure having the garage door opening inwards allows you to open the door with a car parked there, if not opening the door the other way into the laundry hallway will work, we currently have that set up in our rental and I have to angle my car when parking so we can open the door. Good luck, its a great plan Re: Bushmead Estate - WA 5Aug 03, 2020 1:24 pm Mikey92 I'll follow this, because I couldn't afford the extra 50k+ to build there Keep saving - The second stage (Bushmead South) is only a year or two away and you will have some choice of great blocks. Don't worry too much about missing out on the grants - all the builders have increased their prices anyway you will end up paying more. Re: New Build - Bushmead Estate, WA 6Aug 03, 2020 3:10 pm gogo65 Depends on your situation, if you’ve got three kids or planning on having in the future I’d leave it as 3 similar sized bedrooms. If this is your forever home then do what works. Also would depend on the area is a four bedroom home more sort after therefore paying a much higher premium than a 3 plus study? Ideally I would of added and additional 500mm to the length of the house(bedroom side) and made the bedrooms are bit more spacious, allowing for 3 reasonable sized bedrooms. Although the bedrooms say they are 4030 x2980, in reality they are 3300x2980 as the wardrobe takes up 700mm of that space. Just one other comment if I may....I’m not sure why builders still have glass sliding doors in laundries, all they achieve is an area between bench or washing machine and the glass, a moist dust catcher, if you can put a glass normal opening door on there, it will allow you to run cabinetry all the way to the wall. Also just make sure having the garage door opening inwards allows you to open the door with a car parked there, if not opening the door the other way into the laundry hallway will work, we currently have that set up in our rental and I have to angle my car when parking so we can open the door. Good luck, its a great plan Thanks for the feedback - totally agree. Unfortunately with the block size and council requirements, I can't make it any longer - that's why I was thinking reduce Bed 3. I think I will just have to leave as is - messing with Bed 3 may reduce future resale or rental appeal, as the design is more geared toward a decent family home. How big are your bedrooms? Re: Bushmead Estate - WA 7Aug 11, 2020 7:43 pm zoltaire Mikey92 I'll follow this, because I couldn't afford the extra 50k+ to build there Keep saving - The second stage (Bushmead South) is only a year or two away and you will have some choice of great blocks. Don't worry too much about missing out on the grants - all the builders have increased their prices anyway you will end up paying more. Nah man, we had started our planning back in November '19. Chose our block etc. last year in Ellenbrook. The grants are just a bonus given the timing. Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 8 2249 |
