Browse Forums Heating, Cooling & Insulation Re: Master Bedroom above Garage with Balcony very cold 9Jul 17, 2020 4:33 pm Ethanr bestspecials I know that our garage is quite cold because there is a gap around the garage door when the wind comes in. Have a look at putting some expanding foam into the gap and this would make the garage warmer and less cold air coming through your bedroom floor. Thanks. I have now put embaseals on garage sides which is stopping the wind a lot. Also placed some polystyrene on doors. I think now that I sorted garage. The cold air is coming through balcony glass doors. I am thinking of speaking to by builder about commercial grade glass. You better go for double glazing, it is not only the glass but also frame and sealing around it. Re: Master Bedroom above Garage with Balcony very cold 10Jul 23, 2020 10:22 am Get some decent insulation into your floor joists of the bedroom. That way it doesn't matter how cold your garage gets - door open /door closed, your bedroom should be noticeably warmer. What's in the ceiling of your bedroom? Stewie Re: Master Bedroom above Garage with Balcony very cold 11Jul 23, 2020 10:25 am Stewie D Get some decent insulation into your floor joists of the bedroom. That way it doesn't matter how cold your garage gets - door open /door closed, your bedroom should be noticeably warmer. What's in the ceiling of your bedroom? Stewie When you say insulation are you referring Rug or Carpet?. Ceiling of bedroom is roof with insulation. Re: Master Bedroom above Garage with Balcony very cold 13Jul 24, 2020 8:35 am Stewie D No, insulation is batts or similar installed between the floor joists. Stewie No, as per builder there is no insulation batts above garage and the bedroom flooring. Builder said its not mandatory. I would prefer to put insulation but not sure how much it would cost and builder is not supporting it. His view is put rug and curtains and air conditioning. Re: Master Bedroom above Garage with Balcony very cold 14Jul 24, 2020 11:09 am Ha, of course he'd say that. By far the easiest and probably most cost effective solution would be to install R2.5 - 3.0 batts between the floor joists. Of course the sensible thing to do as well would be to install a plasterboard ceiling in the garage after you install the batts. Both easy to do post-build. Stewie Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12671 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2621 Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14280 |
