Browse Forums Kitchen Appliances Re: Ducted rangehood question 3Jul 15, 2020 10:54 pm Fore20 the_doesnotexist In my current (old) house, I’m pretty sure the rangehood is ducted. But instead of going directly outside it seems to be connected to the ducted air con so all the bedrooms end up smelling of food. Is this normal or is this purely because the house is old and they built it wrong? It should vent to outside defintaly not the Air Con!! Thanks. I’ve always grown up with this and now realising this is not an issue for other people. Re: Ducted rangehood question 4Jul 16, 2020 12:02 am the_doesnotexist In my current (old) house, I’m pretty sure the rangehood is ducted. But instead of going directly outside it seems to be connected to the ducted air con so all the bedrooms end up smelling of food. Is this normal or is this purely because the house is old and they built it wrong? If you look closely inside your roof space, it might be the case the sparkies who installed the rangehood connected up some of that silver-type vent tube that looks like the heating tubes. If they did then it might just be a short run of tubing to clear your insulation, that's all. --------------------------------------------------------------------- Check our Homeone build blog here 0 6539 Canopy and Undermount are best, and need to be ducted externally. Which one you go with will be largely determined by your design and joinery choices. What you should be… 1 1457 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
