Hey guys
Is the structural engineer who designed the slab plan for a new build required to inspection the piers and issue a slab certification document during construction?
Is this document required by the Certifier?
We are in NSW.
Many thanks!
Browse Forums Building A New House 1 Jul 15, 2020 6:38 pm Hey guys Is the structural engineer who designed the slab plan for a new build required to inspection the piers and issue a slab certification document during construction? Is this document required by the Certifier? We are in NSW. Many thanks! Re: New Home - Slab Certification by Engineer 2Jul 15, 2020 8:09 pm Hi Jessie It can be any licensed engineer here in WA Check with your Council building department They should have all your certified building documentation on record Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: New Home - Slab Certification by Engineer 3Jan 10, 2021 10:34 pm Jessie2019 ×Jessie2019×Jessie2019Hey guys Is the structural engineer who designed the slab plan for a new build required to inspection the piers and issue a slab certification document during construction? Is this document required by the Certifier? We are in NSW. Many thanks! Just curious, what prompted you to ask this question? Did something happen? I'm wondering about other additional certifications required for new buildings apart from slab certification. I tried googeling my question over the internet and I got a large list of certificates that I've never even heard of like: BREEAM, Green Globes, Living Building, Zero Energy, Parksmart??? Some articles also state that structural engineers and everybody involved in the construction process require to be certified PMP professionals to qualify?? I googled that and I don't even know what the page is all about... Are these things I need to ask for additionally? Is this even accurate? Thank you Re: New Home - Slab Certification by Engineer 4Jan 12, 2021 2:22 pm Depends - however, a structural certificate is not always required although it usually is. Also, usually, an Engineer will inspect - however, certifiers can also complete this inspections for/on behalf of the Engineer. Re: New Home - Slab Certification by Engineer 5Jan 12, 2021 7:17 pm Does structural engineer inspect the piers, and slab reinforcement in Victoria? Re: New Home - Slab Certification by Engineer 6Jan 12, 2021 7:22 pm Yes, an engineer (usually the one who did the design) needs to inspect the foundations before the concrete pour. He will issue a certificate to the building surveyor. Only an engineer can provide the certification. For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7673 3 6317 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 9620 |
